Order Farmall Cub Parts Online
cub s/n
mikes d
01-16-2006 17:30:30
I bought a cub s/n 63600 thats what the tag says in front of the motor. yt mag says the serial # is on the trans housing? thanks
Nat 2
01-17-2006 06:08:42
 Re: cub s/n in reply to mikes d, 01-16-2006 17:30:30
You've got the right one.
steveb05
01-17-2006 04:55:12
Mike, The serial # tag is on the steering casting just below the radiator and behind the steering shaft. There are casting dates on all the large castings. final drive, Torque tube, and engine casting. Also there should be an engine serial# on the engine block just below the intake manifold. on a machined serface it is hard to find if the engine has been painted over a few times.It will not corrispond to the Tractor serial as IH used the engines for a Variety of applications
Mark Scholten
01-16-2006 19:44:20
Is your serial number preceeded by FCUB? If so, then you have a 1949.
Mark
CNKS
01-16-2006 18:03:44
Don't believe that everthing you read on this forum applies to all tractors, as people (myself included) sometimes do not give all-inclusive answers. The SN plate on the Cub is on the right side of the steering gear housing.
