Super C Fuel Strainer Gasket
neyland86
01-03-2006 20:08:58
Just getting into my restoration, where can I find a gasket for my fuel strainer? Thanks Neyland86
gene bender
01-04-2006 04:31:46
 Re: Super C Fuel Strainer Gasket in reply to neyland86, 01-03-2006 20:08:58
Any small engine place will have them also better get rubber as they will last better mite want to check to see that the housing is not sprung as over the years it was over tightened and in the process the lip where it seals is sprung and even a new gasket will not stop the leak.
neyland86
01-04-2006 13:51:25
 Re: Super C Fuel Strainer Gasket in reply to gene bender, 01-04-2006 04:31:46
Thanks!
old
01-03-2006 20:27:50
I pick mine up at the local auto parts store, most of the time I buy all they have one hand and that way I have a few for when I have one go bad. But with 15 running tractors and 5 or 6 others that I work on for a friend I have to keep a few around.
neyland86
01-04-2006 13:52:11
 Re: Super C Fuel Strainer Gasket in reply to old, 01-03-2006 20:27:50
Thanks!
CRUSADER
01-03-2006 20:19:33
Hello Neyland 86,
Had a simular problem with my father's Farmall M. The cork gasket on the fuel strainer was all rotted and dried out. Went to the parts store in town and they had some in stock. These gaskets are not that uncommon in size. You might want to take the bowl with you like I did to ensure that it's the right size. The only sad thing about it is Dad didn't get to drive his old M again. He passed away before he could use it. My nephew is interested in one of his tractors, but not sure which one. This thing needs a lot of work done on it that I had tried to talk him into letting me do when I was home on leave. I am in Korea right now and will hopefully get it and the JD 630 that was my uncles last tractor before he quit farming back together and back in operational for use when I get back to the states.
Good Luck with the gasket.
Jim
neyland86
01-04-2006 13:53:30
 Re: Super C Fuel Strainer Gasket in reply to CRUSADER, 01-03-2006 20:19:33
Thanks!
billde
01-03-2006 20:13:13
Your best bet would be a Case IH dealer or an Agco dealer
neyland86
01-04-2006 13:54:10
 Re: Super C Fuel Strainer Gasket in reply to billde, 01-03-2006 20:13:13
Thanks!
