SMTA add on power steering.
Greasey Hand
12-29-2005 16:28:10
Need help here guys, There is a Charlin-Eaton Power steerng unit on this IH & when running it pushes the fluid out of the stud that holds the cover on, It is not over full.
Would the by pass valve be stuck? Is there any way to run a hose to the live pump
& get by that reservour under the hood?
What a pain that is. It has to be higher than the orbit motor write? Thanks.
the tractor vet
12-29-2005 18:44:57
 Re: SMTA add on power steering. in reply to Greasey Hand, 12-29-2005 16:28:10
There should be a copper washer to seal the nut .
