1466 $$$
Michael Sheik
12-20-2005 07:35:20
Ok, say it needs opened up. What are parts going to cost supposing it needs sleeves, pistons and everthing else mikes out.
What is a reasonable $$$ to qoute for purchase knowing I may need to break it down?
El Toro
12-20-2005 08:33:34
 Re: 1466 $$$ in reply to Michael Sheik, 12-20-2005 07:35:20
A major sleeve and piston kit cost's about $1225.00 from Wenger in Myerstown. That includes
your gaskets, rod bearings and main bearings. Your crankshaft needs to be measured and ground if needed to determine which bearings to order.
I would want to pull the engine too, as the Vet has suggested. Engine probably should be degreased too. If it has removable cam bearings
I would have new bearings installed. This and close tolerances on your crankshaft bearings determines good oil pressure. Hal
the tractor vet
12-20-2005 07:59:04
I don't have and up to date price on the overhaul kits but if ya do it wright with no labor i'll bet ya got around two grand in it and maybe more if the crank needs turned because of being run with antifreeze in the oil . Myself i gave up on inchassie overhauls and i prefer to to pull the engine and do it wright the first time since they are getting old check the line bore deck on the block and have the head done all the way and check the cam and cam fallowers new cam bearings and oil pump. And make sure that it has a water filter on it if not add the kit.
