504 rowcrop to lowprofile
deene
12-15-2005 17:44:05
i have 504 rowcrop with wide front was wanting to use for brushhogging and wanted to get lower to ground...will an industrial frontend bolt up and then put shorter rears on it or am i better off selling and buying an industrial to begin with?
deene
12-16-2005 18:56:07
 Re: 504 rowcrop to lowprofile in reply to deene, 12-15-2005 17:44:05
thanks for the replys guys i had bought this old tractor cpl yrs agao and havent gotten it running well yet..just cpl cylinders firing..i custom brushhog with a 2424 int{with no power steering :( } and thought this would be more horse so i could step up to a 6ft hog and save time..would prefer a hi low trans and no torque but anything like that is very $$$ right now seems like thats what everyone wants..was looking for a cheap way out but i will keep looking i guess..thanks again
Jrry
12-16-2005 12:29:34
I have a Farmall 404 row crop and an International 404 low boy and I think you would be better off finding the utility rather than trying to convert. That way you can have another tractor (can't have too many). I use my 404 low boy to cut the pasture with and does a good job and keeps me below the tree limbs. I realize you are talking 504 and not 404 but I think the same would apply to both.
later,
Jerry
Nat
12-16-2005 05:34:15
There's very little the same between a 504 Utility and a 504 Farmall besides the engine.
Where are you located? If you have a line on a Utility, you have a buyer for the Farmall. I know the 504s are gutless wonders, but I've always wanted one for some reason.
K.B.-826
12-15-2005 21:45:19
The utility version of the 504 used a totally different front bolster than the row-crop. The utility has no frame rails, and the bolster bolts to the engine block. Anything is possible with time and $$$, but you'd be way better off to trade for a 504 Utility. Tons of them out there.
