43 H distallate/gas tanks
Kent in NB
12-11-2005 16:52:48
Decided to tackle the small gas tank on my H . The tank has about two inches of varnish in the bottom, plus junk/gunk! The line to the strainer is full of crud, and the brass tap on the bottom of the small tank will not come out completely. Should that tap be able to unscrew completely out,or will I damage it? What about filling the tank with varsol, or paint thinner, etc...., and letting it work through? Nothing is moving through at the moment, line or tap. Don't really want to remove the tank at the present time. Thanks for comments.Kent.
old
12-11-2005 18:42:04
 Re: 43 H distallate/gas tanks in reply to Kent in NB, 12-11-2005 16:52:48
I'd put a good carb cleaner in that tank and see if that helps. Since its made to clean carbs it should also clean the tank well.
Kent in NB
12-12-2005 03:57:47
 Re: 43 H distallate/gas tanks in reply to old, 12-11-2005 18:42:04
Thanks old. I will try that. My plan is to use this small tank for a little while, so that I can work on the main tank.
