826D Block Heater
KMR
12-05-2005 11:02:08
Where do you install a block heater on a 1970 826D? Did a search for plugs and have come up short.
MN Scott
12-05-2005 19:20:03
 Re: 826D Block Heater in reply to KMR, 12-05-2005 11:02:08
There are no frost plugs on the german's made before the late 70's or so. There are two way's to go, the lower radiator hose heater that in my opinion does not do a good job of warming a diesel block or the tank type heater. For the tank heater you run a hose from the block drain on the left side of the engine block to the tank heater and from the heater to the water pump carrier plug on the left side. The heater will circulate warm water thru the block, works great. Just be sure to get a 1500 watt heater.
KevR
12-06-2005 07:17:39
 Re: 826D Block Heater in reply to MN Scott, 12-05-2005 19:20:03
Scott,
Where can you get Tank Heater from IH dealer?
MN Scott
12-06-2005 08:09:57
 Re: 826D Block Heater in reply to KevR , 12-06-2005 07:17:39
third party image
Your dealer might have them but any auto parts store or farm store will have them. I bought mine from the local farm store, works good. They make them in several power ratings from 500 to 1500 watts. Make sure you get the highest wattage one you can get.
jpsepp
12-05-2005 12:28:23
don't put an either can on that thing!! go to your local case-ih dealer and get one that goes on the bottom radiator hose. not to many 826 tractors out there and a 358 is hard to find also. keep her in good shape
Allan in NE
12-05-2005 14:22:35
 Re: 826D Block Heater in reply to jpsepp, 12-05-2005 12:28:23
What in the world are you talking about?
Every blessed direct start diesel IH ever came out with had either. Where ya been?
Allan
Weldon
12-06-2005 07:37:47
 Re: 826D Block Heater in reply to Allan in NE, 12-05-2005 14:22:35
I have 756 and 856, both 1969 Custom models. Neither of them has ether injection system installed from factory. The Custom models were a "no extras" version of the Farmall. The ether injection was available as a kit to add to a tractor, if so desired.
Allan in NE
12-05-2005 11:11:49
KMR,
This is my 310. Your 358 should be similiar.
Allan
third party image
KevR
12-06-2005 07:11:44
 Re: 826D Block Heater in reply to Allan in NE, 12-05-2005 11:11:49
Thanks for the reply with the Pic Allen, but there is nothing like that on this block. I have searched all over the block and there is no plug big enough for the block heater the IH dealer sold me, in fact I think there is only one plug on the whole block and it is maybe 1/4 inch. It is behind the fuel filters. I Guess I will have to install a canister type.
P Backus
12-05-2005 11:47:01
My goodness! What is that thing out front, a soda can crusher? It"s kind of a funny looking etherizer- never saw one like that. Maybe it holds muffler bearing lube, like Ol" Rog would say. ;>)
Paul
Allan in NE
12-05-2005 11:53:53
 Re: 826D Block Heater in reply to P Backus, 12-05-2005 11:47:01
Naw,
That's just an extra can of compression. :>)
Allan
P Backus
12-05-2005 12:03:20
 Re: 826D Block Heater in reply to Allan in NE, 12-05-2005 11:53:53
I think my 706 is going to need several of those!
Paul
