1939 m farmall
farmallguy3
11-27-2005 08:13:46
my friend has a 39 m that has a push pull cable that goes into the transmission and hookes to an arm that moves a mechanism that had pins in it to engage something. the mechanism is in place of where the spacer would be in the lower part of the tranny. we believe it is not a m&w nine speed. we would like to know what it is. I have some pics but donot know how to up load them. any info would be appreciated
5r4etired
11-27-2005 19:36:53
 Re: 1939 m farmall in reply to farmallguy3, 11-27-2005 08:13:46
Heisler and Behlen also made 9 speeds,If I remember correct the M and W and the Heisler were solid linkage shift, the Behlen used cable.
randy hall
11-27-2005 09:22:12
you have described a nine speed unit.
farmallguy3
11-27-2005 08:52:37
could it be a two speed pto?
DWV
11-27-2005 12:45:45
 Re: 1939 m farmall in reply to farmallguy3, 11-27-2005 08:52:37
Yes it makes the PTO 2 speed also but thats just a side effect of making the transmission dual range.The 2 pins have a splined piece on front end and under front 2 gears on that shaft.It has splines on inside and outside.One side to turn trans shaft and other to lock in whichever range gear its shifted into.I think it is a M&W 9 speed from what you described.
Randy-IA
11-27-2005 17:10:51
 Re: 1939 m farmall in reply to DWV, 11-27-2005 12:45:45
Hi , I have the nine speed and what he's describing is what I have , a push-pull cable going into the side of the trany housing . If the 9-speed changes the pto speed to a two speed , what's the rpm of the high side on the pto ? Mine work's great but I didn't know it increased the pto speed also . Take care ...Randy
DWV
11-27-2005 19:06:44
 Re: 1939 m farmall in reply to Randy-IA, 11-27-2005 17:10:51
On the M&W with cable ,the cable should go in at the center housing between engine and trans and then on into trans through a special hollow bolt that bolts center housing to trans. Don't know the
RPM of pto on high side but its to fast for safe operation of some things at wide open throttle.
Also hydraulic belley pump is speeded up in high range.
farmallguy3
11-27-2005 17:28:32
is there somewhere i can get some schematics for the nine speed tranny m&w made so that we can check to see if this it what we have.
DWV
11-27-2005 19:15:00
 Re: 1939 m farmall in reply to farmallguy3, 11-27-2005 17:28:32
Emailed you if you don't get it post back.
farmallguy3
11-27-2005 17:04:20
 nine speed tranny in reply to DWV, 11-27-2005 12:45:45
