Farmall M Narrow Front End
Richard Fazio
11-26-2005 05:39:06
third party image
I have an M that I want to put a narrow front end on. I got one front end and found out that my rims didn't fit it. Then I got another with the rims. I was comparing the two and noticed they were different. The one on the right slants backward more than the other. Does anyone know what the difference is? Should I use one over the other? It looks like the slanted back one may make it want to straighten out more than the other?
randy hall
11-26-2005 20:43:17
 Re: Farmall M Narrow Front End in reply to Richard Fazio, 11-26-2005 05:39:06
the lower bolster with the lesser angle is from a late m or newer. the late m's had the angle changed for easier steering.
minnimolineman
12-02-2005 18:07:42
 Re: Farmall M Narrow Front End in reply to randy hall, 11-26-2005 20:43:17
Hooray for narrow fronts. I'v got mine with the narrowest spread-- rims bolted to inside of hubs (yeah I know its more pain to change a flat) and it steers a lot easier than if they are set apart farther.
Richard Fazio
11-27-2005 06:14:55
I figured the angle would effect the steering effort. Easier steering is better. The reason I'm changing it out is the wide front is so hard to steer and the turning radius is terrible. Besides the fact that it is totally worn out. Thanks for the info.
DWV
11-26-2005 14:56:23
Most of those have a cast # and a date code on the post.If you could post those someone can tell what they were from.
Richard Fazio
11-26-2005 09:50:54
I think the spindles are the same though I didn't actually measure them. They are both much larger in diameter than the spindles on the wide front that's on the tractor now. That's why I had to get the hubs also. I'll check though. They both came off M's supposidly. Thanks for the info.
ChadS
11-26-2005 09:31:52
The one on the right is what is supposed to be on the M,,,,, The left, may be off a newer tractor, maybe like an 06 or something along that line,,,, Which one has larger diameter spindles? The M may have longer length spindles too,,,, Chad
