Super M X codes
Charles McNelly
11-18-2005 19:20:06
Ok guys, Please pull out your books and figure out what the "X" code means please. This guy is selling a Super M with a serial # L-509-xxxJ. I know it"s a 1953, I just don"t know what the other is. Thanks for all your help.
-Charles
texasoldiron
11-19-2005 19:31:30
 Re: Super M X codes in reply to Charles McNelly III, 11-18-2005 19:20:06
When I listed the tractor, I could not make out the last serial numbers. I have since modified the ad. WOW, got a lot of responce on it!
THEkyroastnear
11-19-2005 06:34:12
i took it the seller could not make out what the other 3 nos. were in the serial plate
CNKS
11-18-2005 19:44:24
You don't show any X codes, the J means the clutch was built by Rockford, that L prefix means the tractor was built in Louisville, Kentucky. I assume the xxx are digits that you have not listed, as Louisville Super M's had 6 digit serial numbers. In case the last digit is followed by an X and some number, or an X, then a number, then a letter, you need to let us know what they are.
jakee
11-18-2005 20:35:42
 Re: Super M X codes in reply to CNKS, 11-18-2005 19:44:24
i think it means hi-comp-gas
CNKS
11-19-2005 06:23:41
 Re: Super M X codes in reply to jakee, 11-18-2005 20:35:42
Probably, but there are about 25 X codes that don't have a 1 in them.
DWV
11-19-2005 09:37:32
 Re: Super M X codes in reply to CNKS, 11-19-2005 06:23:41
Failed to notice tractor was listed for sale
first time I read.I agree with thekyroastnear.
DWV
11-19-2005 09:30:52
Don't think there was any X codes used on any serial numbers for SM.Thought he could be refering to date codes on tractor which could still be a 53 tractor and have some X or all X on castings if early 53 tractor.Won't know unless
he posts back.
CNKS
11-19-2005 12:49:03
 Re: Super M X codes in reply to DWV, 11-19-2005 09:30:52
You are probably right, my Super H (don't have a Super M) with gasoline engine does not have X1 after the serial number, never thought about that until now. My 460 does not have an X suffix. Guy Fay says they were used until "sometime in the 50's".
