found some wrenchs
fisherman
11-17-2005 10:20:19
Cleaning out the dirt/munure from a real old barn and found a box full of wrenches. They look old. Some of them say ford and some of them say pitman several don't say a thing. Some of them are awkward in shape, does anyone know a thing about them? or anything to look for?
Also, my M won't turn over in the Cold weather, any suggestions. Thanks in advance.
Boos
11-18-2005 03:45:37
 Re: found some wrenchs in reply to fisherman, 11-17-2005 10:20:19
WOW talking wrenches. You mean they actually said that?
Richard Cranium
11-17-2005 18:35:43
The wrenches were used to remove nuts and bolts. Wait till it warms up to start your tractor.
Mingo
11-17-2005 16:51:42
If you could post some pictures and any markings or partnumbers, I may be able to help. Bob
RustyFarmall
11-17-2005 13:18:19
The Ford wrenches could be model T or A. The others? I don't know. Some folks do collect old wrenches, so don't just throw them away. I doubt if there is any immense value in them.
fisherman
11-17-2005 13:50:35
 Re: found some wrenchs in reply to RustyFarmall, 11-17-2005 13:18:19
Thanks, I will hold onto them- By all means I need more things :)
They were covered up by burlap in the corner of a real old barn that I was cleaning to keep a tractor for restoration- Not the greatest building but still standing and sorta dry but out of the wind.
captaink
11-17-2005 10:46:51
When you say “won’t turn over” I presume you mean with the starter. For temps below freezing I recommend 10W-30 or even lighter (5W-20) for below 0 F. I would also suggest a tank heater, and/or a magnetic heater for the oil pan. All will help the engine turn over.
Of course this already presumes that you have a good battery with adequate amperage, clean battery connections, adequate sized battery cables (00 for six volt 2 for twelve volt), and clean metal to metal contact on the starter nose, field housing, and brush end plate.
Janicholson
11-17-2005 17:04:40
 Re: found some wrenchs in reply to captaink, 11-17-2005 10:46:51
Well stated Captain
JimN
