806 injection pump
bgud
11-16-2005 19:28:59
Hi I have a question on an 806 diesel. I am trying to install the injection pump and my I & T manual shows the 806 has an RD pump and the 706 has a roosa-master. My tractor has a roosa-master. Any help with the timing would be very helpfull. Thank you in advanced
K.B.-826
11-16-2005 20:30:09
 Re: 806 injection pump in reply to bgud, 11-16-2005 19:28:59
Keep reading, the procedure should be in there. You're looking at I&T manual IH-32, right? Look at paragraphs 170 and 174. Should be timed 8 degrees BTDC. Early 806's came from the factory with the RD pump, but about 90% of them have been replaced with Roosa-Masters.
bgud
11-17-2005 07:06:04
 Re: 806 injection pump in reply to K.B.-826, 11-16-2005 20:30:09
Hi I don't know if it matters but I have the IH-26 manual. It shows to set the pointer on the flywheel to 50 degrees, 8 degrees sounds alot better. Thank you for the info
