LoBoy float level
Ken C.
11-16-2005 14:20:12
Does anyone know how to check the float level on my '58 Cub LoBoy? I have the carb apart, soaked over night, putting in new needle & seat, & would like to check the float level before I put it back togather.
Thanks, Ken C.
El Toro
11-17-2005 05:02:40
 Re: LoBoy float level in reply to Ken C., 11-16-2005 14:20:12
The float level is measured from the upper body of carb to the bottom of float. Should be 1 -13/32". Hal
Ken C.
11-17-2005 08:53:27
 Re: LoBoy float level in reply to El Toro, 11-17-2005 05:02:40
Hi Hal,
I saw that float measurement in my IT manual, but I think it only applies to the std. cub. The reason I say that is because my LoBoy float is vertical, not horizontal like most floats. Does this still apply here?
Thanks again,
Ken C.
El Toro
11-17-2005 10:46:29
 Re: LoBoy float level in reply to Ken C., 11-17-2005 08:53:27
The Cub carburetor is called the 3/4 updraft in my manual. Someone on the Cub forum may have a shop manual on the Lo-Boy carburetor. Hal
PS: Call this number 1-800-732-0017 and ask for farm tractor service. They will fax you the info
or tell you over the phone what the setting is.
El Toro
11-17-2005 08:57:55
My manual only list's the Cub, nothing about the low-boy. Put this question over on the Cub forum
and I'm sure someone over there has the answer.
There's probably a difference. Hal
