1957 IH 350 Utility Plow Depth Gauge
Dave Maniez
11-08-2005 19:38:09
Guys, I'm looking for a plow depth gauge for my late father in laws 350 Utility that I have restored. I may not be calling this the correct name but I will attempt to describe it. It is roughly 3" wide and 10" tall black plastic with 2 (?) needles and mounts on the right side of the dash/hood. It has two cables that run back and connects to the 2 point fast hitch. I have been told that it was an option when the tractor was bought new ? If I'm way off , I appologize. I haven't seen it, I'm just going off hearsay. All I know is there are two holes still in my tractor where it was mounted that I would sure love to fill with an original gauge. If you can help in any way, even with correct info or a picture of one so I know what I'm really looking for. Please email me. THanks, Dave
Dellbertt
11-09-2005 18:11:38
 Re: 1957 IH 350 Utility Plow Depth Gauge in reply to Dave Maniez, 11-08-2005 19:38:09
You might try Stamm Equipment, Wayland, Michigan.
They might have one layin around.
Dave Maniez
11-09-2005 18:17:05
 Re: 1957 IH 350 Utility Plow Depth Gauge in reply to Dellbertt, 11-09-2005 18:11:38
You wouldn"t have a phone # for them? and am I calling it the corect name?
Thanks, Dave
Redned
11-09-2005 18:02:00
Dave
Dellbertt got it right.Traction control.I am restoring the one I have on my 350u.Its not plastic but metal.The problem is the elements and age(abuse) seems to get the best of them.Numbers start to fade, needle stuck.Try some of salvage yards.If you can't get one maybe I can take some pictures.Do some fabricating.
Dave Maniez
11-09-2005 18:24:16
 Re: 1957 IH 350 Utility Plow Depth Gauge in reply to Redned, 11-09-2005 18:02:00
Thanks, If it wouldn't be too much trouble for you to take some pictures and send them to me at dmaniez3@aol.com I would really appreciate it. I really don't know where the cables hook up or anything. Send me your email and I will send you a picture of my 350 :) I will check to see how hard it is to add pictures to the Photo gallery. Check in a bit and if I can get them entered, they will be under Dave's ... Thanks, Dave
Dave Maniez
11-09-2005 19:45:19
 Re: 1957 IH 350 Utility Plow Depth Gauge in reply to Dave Maniez, 11-09-2005 18:24:16
I tried to upload the pictures with no luck so, if you give me your email I will send it to you.
Thanks, Dave
Dellbertt
11-09-2005 13:05:39
Dave, its called Fast-Hitch with Traction Control. Ref.IH Parts Catalog TC-57A IH 300U & 350U issued 5-"60. Page 337. Pictorial A-48126 The Guide Part No. 367 201 R11. The Guide looks similar to a hanging scale indicator. Your IH Dealer should be able to give you a copy of the pictorial. If not contact me and I will send a copy.
Dave Maniez
11-09-2005 18:19:21
 Re: 1957 IH 350 Utility Plow Depth Gauge in reply to Dellbertt, 11-09-2005 13:05:39
Thanks for the info. If you have the # to Stamms I will give them a call.
Thanks again, Dave
