For Rusty Farmall
Too Far Gone
11-08-2005 15:12:09
Im sorry about taking so long to get back to you with my M Engine #FBKM 1368 ME X1.Ive been real busy.I have a 1947 M.Is this the correct block?Any help appreciated.Thanks
Too Far Gone
11-09-2005 18:40:30
 Re: For Rusty Farmall CASTING NUMBERS in reply to Too Far Gone, 11-08-2005 15:12:09
OK,The engine casting #6722 DJ,Tranny casting # is 6002 DB,and the narrow front pedestal casting #6719 DB.I hope this helps.Thanks Guys
RustyFarmall
11-08-2005 18:32:44
 Re: For Rusty Farmall in reply to Too Far Gone, 11-08-2005 15:12:09
Serial number 1368 makes the engine a 1939. Going by your description of the tractor in the earlier post, I think it is safe to assume that the tractor is indeed a 1939. Either someone has changed the serial number tag, or as stated before, the torque tube that the serial tag is attached to has been replaced. In this case the torque tube was donated by a 1947 M. Another thing to look for would be the casting codes. This a rised number, located on just about every part of the tractor that is made of cast iron. It will appear as 7*14*I. The number 7 being the month, 14 is the day, and the letter I being the year, in this case 1939. A different letter was used for each year of manufacture. I-39, J-40, K-41, etc. Quite a few of the tractors made in 1947 actually had 47, instead of a letter. The letter for 1947 would be Q.
Too Far Gone.
11-09-2005 18:52:22
 Re: For Rusty Farmall I found the suffixes ! in reply to RustyFarmall, 11-08-2005 18:32:44
My tractor is indeed a 1940.The letter J is on every part from one end to the other.Thanks a lot
DWV
11-08-2005 19:11:23
 Re: For Rusty Farmall in reply to RustyFarmall, 11-08-2005 18:32:44
One problem,don't think any 1939 engines in M tractors were stamped with X1.
CNKS
11-08-2005 19:37:02
 Re: For Rusty Farmall in reply to DWV, 11-08-2005 19:11:23
Correct, Guy Fay's data book says the first gas engine was in chassis serial 18144, that makes it late 1940.
RustyFarmall
11-09-2005 04:23:29
 Re: For Rusty Farmall in reply to CNKS, 11-08-2005 19:37:02
So maybe we are all still in the dark here. I have never seen the X1 following the serial number on an engine, the tractor serial number yes, but not on the engine.
CNKS
11-09-2005 05:53:05
 Re: For Rusty Farmall in reply to RustyFarmall, 11-09-2005 04:23:29
Also, the E means 8000 ft altitude, the M low speed attachment -- don't know why IH would put the M on the engine serial.
DWV
11-09-2005 15:34:38
 Re: For Rusty Farmall in reply to CNKS, 11-09-2005 05:53:05
We need more info.Suffix codes should follow the X-1 on tractor engines. TFG are the # and letters all in straight line sometimes the X-1 is stamped below serial #? Also is the M E easy to read or could they be more numbers?
Too Far Gone
11-09-2005 18:25:10
 Re: For Rusty Farmall in reply to DWV, 11-09-2005 15:34:38
FBKM 1368 is the top line.Below it goes like this ME X1,and its plain as day-not hard to read at all.I'll get some #'s from castings and get back in a few minutes.Thanks Everyone.
chadd
11-09-2005 04:42:43
Yep, they did also put the x1 on the engine serial number as well as the chassis serial number. Our W6 has the x1 on both, but our 1940 M has no suffix codes on either plate. Must have been something that they started later.
