Installing 291 gas motor in 460 Farmall??
migraine
11-08-2005 08:55:42
Have a 460 Farmall wide front with bad diesel motor and found a 666 gas motor , a 291 that needs rings and head work and was thinking about installing that into the 460. Has anyone done that and what do I need to make it all happen. Has the carb, manifold and flywheel with it but maybe the clutch and flywheel will have to come from the 460? Any help would be appreciated. Thanks Migraine
ejr-IA.
11-08-2005 16:44:06
 Re: Installing 291 gas motor in 460 Farmall?? in reply to migraine, 11-08-2005 08:55:42
It will work no problem,but you will need to visit the salvage yard for the front motor timeing cover and the motor plate and oil filter base that the oil canister goes on.Flywheel and rear motor plate will swap over from diesel.Carb inlet faces forward on 666 and rearward on 460 think you can use the dry air cleaner off the 666 on the 460 ,I did this on a 560.My 460 has a 715 301 gas did the same as I told you above.
