685 brake problems
MNredfarmer
11-04-2005 17:13:56
I have a CIH 685 with brake problems. Every once in a while I have to bleed them, sometimes they hold for a few days and sometimes only a day. The right brake has been holding for a couple of weeks now. I bought the tractor in January and it's been real good, with the exception of the brakes. It's a MFD model. Is there anything else I should be prepared for? THANKS
Bernard le mécano
11-05-2005 06:08:50
 Re: 685 brake problems in reply to MNredfarmer, 11-04-2005 17:13:56
Hi MN, try to bleed the brake system,stop the tractor for 1 or 2 days and check one pedal at the time to see wich is the side in trouble. Unlock the pedal to make the test, because, if you press both pedal, it have an equaliser valve in the system. The pedal that goes down have a leak in the piston. Bernard le mécano Québec Canada
MNredfarmer
11-05-2005 11:15:56
 Re: 685 brake problems in reply to Bernard le mécano, 11-05-2005 06:08:50
Thanks for the reply, will do that but will have to wait till Mon. or Tues.. I will need to use it for the next couple of days.
JB2
11-04-2005 20:30:47
Hi MNRed, do a search in the archives on Bernard.
There you should find Bernard le mecano's procedure for testing the brakes for a leaky cylinder. I think it was on an 885 but is same setup as 685.
JB2
