rust preventer
mwkellner
10-31-2005 14:48:31
I have LOTS of thick rust that built up between the wheel and weight on 1968 cub. I have spent about an hour banging it off with a ball-pin hammer and wire wheel. What is the best product (available in a hardware store) to use to prevent further rust? Ospho, naval jelly? I am going to turn the wheel around so looks aren't as important as stopping the rust. Thanks alot for your responses.
Martin
George Wallace
11-01-2005 07:06:23
 Re: rust preventer in reply to mwkellner, 10-31-2005 14:48:31
Most of these solutions contain phosphoric acid. This acid turns iron oxide (rust) to iron phosphate (nice black finish suitable for painting). I also use it on old tools, old cross cut saws and in general any old rusty stuff that I want to hang on the wall. I use a spray bottle to spray the tool and then just leave it. Gives it a real nice apperance. H3P04 is also used in Coke. Thats why Coke is such a good cleaner. Leave a penny in Coke for about a month and it will disolve!
max adams
10-31-2005 16:37:08
Ospho hands down! Like they said blast or sand, Use Ospho, then prime and paint. Ospho gets into the pitted areas. Thats my two cents! Max
El Toro
10-31-2005 15:01:27
You would be better off to have them sand blasted
and primed with some good primer paint and then
have them painted with a good top coat. Doing
this will last a long time. Hal
Harry H
10-31-2005 15:20:26
 Re: rust preventer in reply to El Toro, 10-31-2005 15:01:27
The auto parts store ,Oreily, has a product--ONE STEP--- that converts rust to black primer sealer. The part # is 3509 --brand name mar-hyde, byBondo Corp.
Pale Rider
10-31-2005 19:07:53
 Re: rust preventer in reply to Harry H, 10-31-2005 15:20:26
I'll second that on the One Step, or it's sometime counter part - Three in One. I've been very happy with the results.
