farmall A ,B ,C fan assembly
will sick
10-28-2005 20:09:49
The fan assembly on my Super A leaks oil. Can they be repaired? What does one need to replace? I haven't been over filling it.
CNKS
10-29-2005 11:52:00
 Re: farmall A ,B ,C fan assembly in reply to will sick, 10-28-2005 20:09:49
You can get a new one with sealed bearings (no need to oil) from Steel Wheel Ranch -- 785-548-7437. For the price Mike sells them for, I wouldn't mess with fixing it unless you are a purist.
Andrew Z
10-29-2005 12:54:34
 Re: farmall A ,B ,C fan assembly in reply to CNKS, 10-29-2005 11:52:00
I put a "O" ring on the shaft of my Super C and that cured that issue. Alos there are gaskets that are on the fan hub make sure to check those to. Andrew
gene bender
10-29-2005 04:32:00
Depends on how bad does it wobble on the shaft and how much end play. Put a piece of leather on the shaft at the rear where the machined nut is.
Retired 05 in VA
10-29-2005 05:31:04
 Re: farmall A ,B ,C fan assembly in reply to gene bender, 10-29-2005 04:32:00
What would the maximum acceptable end-play be before you would consider the idea of replacement?
