Need some tin
Chad overmyer
10-26-2005 09:36:02
need tin work for an international harvester 460 diesel. restoring for a highschool project and have to get it done to graduate. any info would be helpfull. thankyou
El Toro
10-27-2005 06:49:09
 Re: Need some tin in reply to Chad overmyer, 10-26-2005 09:36:02
If you're referring to the sheet metal on your tractor that needs to be straighten you should
have a body shop to do this and you do the painting. If it's damaged too much to straighten
you probably can buy good used parts. Hal
migraine
10-26-2005 15:02:02
Are you talking about a International 460 Diesel utility or a Farmall Row crop Diesel. Tin work is different on these two tractors. Migraine
