F-12 Fuel Pump
Dick Hamilton
10-25-2005 14:12:22
Can the diaphram be replaced and if yes, can you get a replacement? Mine hadn't been run in at least 10 years and when it was they had a old gallon milk jug setting up high enough for gravity. I have been working on it finally and am about to the point where I will want to give a crank. Dick
El Toro
10-25-2005 14:19:59
 Re: F-12 Fuel Pump in reply to Dick Hamilton, 10-25-2005 14:12:22
Check with thefordsonhouse at 906-786-5120 or email info@thefordsonhouse.com, they have gasket sets for the 10-20's. Hal
pgo12
10-25-2005 14:40:05
 Re: F-12 Fuel Pump in reply to El Toro, 10-25-2005 14:19:59
rice equipment has rebuild kits for the 12s fuel pumps. 814-226-9200. pg
Dick Hamilton
10-25-2005 14:44:50
 Re: F-12 Fuel Pump in reply to pgo12, 10-25-2005 14:40:05
Thanks for the answers. I"ll take it from there. Dick
moseed
10-27-2005 06:22:58
 Re: F-12 Fuel Pump in reply to Dick Hamilton, 10-25-2005 14:44:50
Dick,
There are at least two kinds of diaphrams in the F-12 fuel pump. One kind you can replace the rubber diaphram and reuse the plunger thingy that it was attached to with little screws. The other has the diaphram permanently attached to the plunger thingy. Take yours apart before you order the rebuild kit so you can discribe which it is to your parts source. Good luck!
Dick Hamilton
10-31-2005 13:53:06
 Re: F-12 Fuel Pump in reply to moseed, 10-27-2005 06:22:58
Thanks for all the help. Took it apart today and the rubber diaphram looked good. Put it back together and saying a prayer. I've got to get the fuel lines fixed up next and then I can give it try. Dick in the beautiful Finger Lake Region of NYS.
