504 gas
ps
10-25-2005 13:54:56
I have a 504 gas with a c153 engine,it has a lot of blowby do these engines have sleeves,or does the block have to be bored outany help would be great
Hugh MacKay
10-25-2005 18:24:06
 Re: 504 gas in reply to ps, 10-25-2005 13:54:56
ps: No sleeves is correct, I've been there and done that. This was 30 years ago and my understanding at that time, was you don't have a lot of thickness for boring.
Catskill Pete
10-25-2005 16:24:27
No the C 153 gas engine used in the 504 does not have sleeves
El Toro
10-25-2005 14:07:01
I don't think the C153 gas engine had sleeves.
The C188 diesel engine did. Hal
PS: It could probably be bored oversize.
ps
10-26-2005 18:39:13
 Re: 504 gas in reply to El Toro, 10-25-2005 14:07:01
thanks for the help i guess i just need to do it.i wonder if i can get away with just putting rings in it and honing the cylinders it runs great now ,just alot of blow
El Toro
10-27-2005 04:12:21
 Re: 504 gas in reply to ps, 10-26-2005 18:39:13
You could probably just put a set of new rings in it if there's no grooves worn into the cylinder walls. You may have a broken ring and you will need a ridge reamer to cut away the ridge so you don't damage the pistons. The best way to check for wear is to measure the cylinders. You should have a shop manual that covers that 153 engine. The ring gap on a new ring will also determine if the cylinders are worn too much. My IH manual
doesn't cover the 504, but it does list the ring gap for Farmall H with the C152 engine and the ring gap should be .007" to .017" on a new ring.
You need close bearing clearances too and that includes cam bearings for good oil pressure. New gears in the oil pump if worn severely too. I do have a sketch of that oil pump listing the parts.
If you're in doubt about the wear have someone measure the cylinders. You may need new piston pins and bushings since they can cause noise with new rings. Valve guides need to be checked for wear too. Hal
