B oil pressure
donwisc
10-20-2005 18:42:10
Cant get the current gage on the B loose to check pressure with another gage.
Can oil pressue be checked installing a gage at the oil drain plug below the oil filter?
El Toro
10-21-2005 10:00:42
 Re: B oil pressure in reply to donwisc, 10-20-2005 18:42:10
If it goes into the oil filter there should be pressure there. Hal
robertw
10-21-2005 08:47:45
Ihave a farmall sh that i put a oil guage with numbers in the oil filter drain and worked just fine read the same as the one on top i had both the same time just wanted to see what the actural pounds were
AC Hodges
10-20-2005 20:19:33
Don't think that will work. I use one of those pipe wrenches with the rubber strap to get the gauge out.
