W400 gas, fresh OH won't run?
WarrenBinKY
10-15-2005 01:09:48
I have a W400 gas (264) that we just overhauled, rebuilt dist. and carb. Now that she's back together it will not run. It will start, but the only way she will run is to spray ether over the breather. other wise it just coughs a few times and dies. Any advice or ideas would be greatly appreciated. Thanks so much.
Nebraska Cowman
10-15-2005 03:42:50
 Re: W400 gas, fresh OH won't run? in reply to WarrenBinKY, 10-15-2005 01:09:48
I think you found your own trouble. It is not getting fuel. take the plug out off the bottom of the carb and see if fuel runs out then trace or correct acordingly. You won't be the first guy that had to take a carb apart the 2nd or 3rd time to get it right.
Janicholson
10-15-2005 07:44:52
 Re: W400 gas, fresh OH won't run? in reply to Nebraska Cowman, 10-15-2005 03:42:50
The best policy is to fix one thing at a time (unless there is a basket of obvious problems) A wise man told me to repair one thing and analize the result.
Fuel and clean screens (see Archives for vast quantities of how)
Good luck
JimN
