upper radiator hose for 330 utility tractor
Ron Preszler
10-13-2005 21:20:08
Any one know were I can get a new upper radiator hoses for a 330 utility tractor. the hose can not be obtained from IHC any longer, the part # 368600R1. I have looked at the parts stores for a molded hoses I could make work, but had no luck. The size is rather odd, top measures 1 5/8 lower measures 2 3/4 at 90 degrees. Any Ideas!!
Ron Preszler
10-25-2005 20:06:30
 Re: upper radiator hose for 330 utility tractor in reply to Ron Preszler, 10-13-2005 21:20:08
Found a hose to work on the 330. Part # is 369094R1 I had to trim off a small amount no the radiator end. The hose is for the 340 tractor.
DNC
10-15-2005 18:51:49
I had the same trouble on my 330 I think I used a 340 hose.
PAULIH300
10-14-2005 17:16:02
The original IH number doesnt cross over to Gates.You may have to take your hose to a NAPA or some other parts store and hope the illustrated guide has a hose thats close enough.Maybe a flex hose?
El Toro
10-14-2005 16:10:11
I called the IH dealer in PA and they didn't have a hose listed anymore. They did say they would
check other sources and get back to me. I may call them again on Sat. If I find anything promising I'll post the info.
You may have to Jerry rig it using 2 hoses. Give Gates Rubber a call on Monday at 1-800-366-3128 or email [email protected] to see if they made a hose for your tractor. This may not be in your area, but should be able to provide info.
Hal
