4314 proper rear oil?
bcPA
10-13-2005 13:47:59
a friend has just bought a int 4314 with a bc144 gas engine It has a hi + low range with a reverser and a 4 speed gear box. Right now he needs to know the proper oil for the rear. Any other info would be appreciated such as years produced and any other thing of interest you may think of.
Ernest
10-14-2005 07:49:53
 Re: 4314 proper rear oil? in reply to bcPA, 10-13-2005 13:47:59
We have a 3444 loader tractor (nearabouts the same thing) The book recomends HYtran (or we use the equivelent of hytran) Just read the generic oil container and if it says its a replacement for hytran, "it is".
By the way the hydraulic system takes oil from the rearend. No seperate tank.
MJ in the UK
10-14-2005 04:49:24
Here in the UK were your tractor was made 90 gear oil is recomended MJ
catmandoo
10-13-2005 19:10:16
i believe mine has a 3 speed with shuttle,is this what you refer to as a reverser??is it a backhoe??
