656 trouble
sandhill farm
10-03-2005 21:40:11
I've got a 656 hydo, that has developed engine trouble, it runs very rough, and has little power. I've changed the plugs, points, checked the cap, wires and rotor, all ok. Any suggestions of what to try next?
ny bill
10-04-2005 09:48:58
 Re: 656 trouble in reply to sandhill farm, 10-03-2005 21:40:11
check the compression. your symptoms sound like mine did when the head gasket let go between 2 cylinders.
Nat
10-04-2005 08:47:27
You "checked" the cap, rotor, and wires? Visual inspections do not always reveal problems. Replace them with new anyway.
Have you checked the timing?
K.B.-826
10-03-2005 22:03:00
Possible carb trouble? If not, it's compression test time. The IH six-cylinder gas engines require low-ash oil. If you run anything else, they will burn a valve once a year.
