660 TA low side trouble
Justin Imhof
09-18-2005 20:20:52
TA was working and was working tractor pretty hard and having troulbe getting out of gear so went to shop to adjust linkages. Parked for a few hours, made adjustments, took off and when TA lever is pulled back it growls. When lever is back only growls and keeps going in high, but high works fine. took cover off of top of TA and clutch seems to be engaging/disengaging but when ta clutch is turned by hand can hear a little noise like loose parts in there somewhere. Also can wiggle cluth assembly slightly cant remember if this happens in high or low though. Whats happening? is it in the ta clutch or in planetaries? Any help Appreciated.
