Thrust bearing on steering shaft for an H
muley
09-17-2005 08:25:14
Which way does the steering shaft thrust bearing go on a 1945 H? Wider surface facing up or down? Thanks.
Aces
09-17-2005 10:38:01
 Re: Thrust bearing on steering shaft for an H in reply to muley, 09-17-2005 08:25:14
muley the bearing will only go on one way because of the radius on the shaft, the flat wider surface up.
