Super C engine oil, filter?
leon
08-25-2005 03:53:49
I don't have my manuals yet, but what engine oil and filter are appropriate for a Super C?
What about transmission and hydraulic oil?
What does the original manual say?
Ludwig
08-25-2005 15:06:28
 Re: Super C engine oil, filter? in reply to leon, 08-25-2005 03:53:49
If you only use it in warm weather, or if in cooler weather you're real good about letting it warm up you can use 15w40 oil too. A good diesel oil like Delo 400 would be a fine choice.
Randy in NE
08-25-2005 04:49:40
The oil filter element is part # 355009R1. These are readily available from you local Case/IH dealer or you can cross it to a NAPA, etc part number. There have been many discussion on this board concerning the various oils. I use straight 30W detergent oil in my C's because I do not use them in the winter. The other option would be to use 10W-30. The rearend takes about 5 gallons of 90W rearend grease. The hydraulic system takes about 3 quarts of a good quality hydraulic fluid. Fill it to about 1/2" below the fill plug. There is also a screen that you can clean on the left side of the hydraulic unit. The gasket (350651R91) is available from Case/IH. There was a very informative post last week concerning the various brands and their compatability with IH Hytran. Essentially any of the name brands meets or exceeds the Hytran specifications.
