Wide Front Change
krazy-ken
08-21-2005 07:56:24
Found a good 504 wf will it fit under my smta thanks KEN
old
08-21-2005 08:06:56
 Re: Wide Front Change in reply to krazy-ken, 08-21-2005 07:56:24
How many wide front ends do you want?? I know a place here in Missouri that has a good number of them just laying around on there lot.
Cotton Picker
08-22-2005 08:09:02
 Re: Wide Front Change in reply to old, 08-21-2005 08:06:56
Where? Need parts for one.
old
08-22-2005 08:44:26
 Re: Wide Front Change in reply to Cotton Picker, 08-22-2005 08:09:02
It in a little town just north of I-44 its called Richland Mo.
Cotton Picker
08-22-2005 08:48:02
 Re: Wide Front Change in reply to old, 08-22-2005 08:44:26
Is there a name to go with this place? I am in Mississippi and would like to call them.
old
08-22-2005 08:55:31
 Re: Wide Front Change in reply to Cotton Picker, 08-22-2005 08:48:02
The name of the place is brackets. there number is 573-765-4406
Cotton Picker
08-22-2005 09:06:04
 Re: Wide Front Change in reply to old, 08-22-2005 08:55:31
Thanks much! Wide fronts on old tractors are rare down here.
old
08-22-2005 09:13:47
 Re: Wide Front Change in reply to Cotton Picker, 08-22-2005 09:06:04
Depending on the brand they are here also. Most farmalls in the area unless they are say a 706 and bigger all have trike fronts here. And on Olivers your lucky if you can even find a wide front end under one and when you do find one you pay a mint for it.
Hugh MacKay
08-21-2005 08:04:42
Ken: If the wf is a 504 factory original, it's too light to bother with. 504 factory had tyrods out front. Not 100% sure but bolt pattern on tractor front casting is different also. Some folks have inter changed them with modifications.
