one more question for hugh
mitchp
08-05-2005 06:09:36
my right brake on the farmall 140 is a little slack, it goes down further then the left one and could use a little adjusting. i saw underneath you should loosen 2 nuts and probably screw that rod but which way do i need to move it to get more brake, any tricks to doing this?
Hugh MacKay
08-05-2005 22:18:48
 Re: one more question for hugh in reply to mitchp, 08-05-2005 06:09:36
mitch: You've got that one, I've forgotten which way to turn. It should have locking nuts, so if you back those off, shortening the rod will also shorten brake pedal travel. These can sometimes be a bit contrary, may take penetrating oil or even heat.
