gear oil leak
DaveF.
07-21-2005 07:36:55
I have a 1951 Super C with a leak between the center of the clutch housing and the rear end housing. I'm afraid to tighten anymore. I don't see a gasket or seal in my parts manual.Before I take it apart does anybody have any ideas?
scotty
07-21-2005 09:36:29
 Re: gear oil leak in reply to DaveF., 07-21-2005 07:36:55
Dave, There is a seal at the front of the transmission, if that is leaking you need to split the case at that point and replace.
scotty
Andy Martin
07-21-2005 09:07:39
If it is a seal leaking on the front of the transmission so you will not stop it by tightening the bolts.
