Rod's 4cyl gas
iester
07-16-2005 14:13:00
Which way do the rod's turn when facing front of block? (#1 rod) long end right or left? (#2 rod)long end right or left?(#3 rod) long end right or left?(#4 rod) long end right or left? HELP I NEED THIS INFO SO I CAN CONTUINE WITH REBUILD.THANK'S LESTER
El Toro
07-17-2005 04:27:06
 Re: Rod's 4cyl gas in reply to iester, 07-16-2005 14:13:00
The numbers on the rods face toward the camshaft. Hal
riverbend
07-16-2005 21:46:07
The rods and caps should be marked 1-4. The marks go in the camshaft side. Be sure to try turning the crank as you put each set together. If it is too stiff, loosen the cap and make sure that the rod and cap are square with the crank ( and you have 0.002-0.003" clearence with plastigage).
iester
07-16-2005 22:26:46
 Re: Rod's 4cyl gas in reply to riverbend, 07-16-2005 21:46:07
I no which rod and cap goes together and what order...What i don't no is..Same question?Long side of rod(Rod only)Right or Left?My cam is left of pistons when facing front of block..IH 350 UTILITY 4CYLINDER 175 CID MOTOR
Nebraska Cowman
07-17-2005 03:51:52
 Re: Rod's 4cyl gas in reply to iester, 07-16-2005 22:26:46
right or left is determined by setting on seat facing forward. But seeing as you are confused, the long part of the rod goes on the camshaft side
Nebraska Cowman
07-16-2005 14:24:24
first thing, they all go the same way. rods on a clockwise turning engine long side goes on the right or camshaft side. this also the side the are numbered on.
iester
07-16-2005 20:46:13
 Re: Rod's 4cyl gas in reply to Nebraska Cowman, 07-16-2005 14:24:24
My cam is left of rods when facing front of block. so....long sides left? It's a 350 utility 4 cyl,gas,175 cid
Nebraska Cowman
07-17-2005 05:59:55
 Re: Rod's 4cyl gas in reply to iester, 07-16-2005 20:46:13
Let me ask you a question iester, If I am facing you and you reach out to shake my hand does my right hand become left?
Nebraska Cowman
07-17-2005 05:56:18
seeing as you insist on arguing and looking at yours backwards, yes.
iester
07-17-2005 14:00:31
 Re: Rod's 4cyl gas in reply to Nebraska Cowman, 07-17-2005 05:56:18
Thanks cowman for keeping me straight,I wasn't trying to argue.I just want to be sure it's my first rebuild and trying to get it right.I see now that when talking about tractors right or left should be expressed when viewed from tractor seat.Thanks again everbody.
