W6 Miss
Yugrotcart
07-14-2005 15:17:31
My W6 has a miss at slow to mid throttle,not as bad at full throttle. Carbs rebuilt, new plugs, wires points and condenser. Thinking maybe valve adjustment?
BIG JOHN
07-14-2005 15:24:07
 Re: W6 Miss in reply to Yugrotcart, 07-14-2005 15:17:31
You are on the right track. It sure sounds like it is a valve that is adjusted to tight.
GOOD LUCK
RustyFarmall
07-14-2005 17:32:35
 Re: W6 Miss in reply to BIG JOHN, 07-14-2005 15:24:07
Could also be excessive wear in the distributor. Drive gears, bushings, etc.
Yugrotcart
07-14-2005 17:45:32
 Re: W6 Miss in reply to RustyFarmall, 07-14-2005 17:32:35
Mine has a mag. Had it apart today, seems O.K. I will adjust the valves and see what happens,Thx
Yugrotcart
07-14-2005 15:27:11
Thanks, I saw the other day to set them @19 thou cold, now I just need someone to come crank the engine so I can set them up..... ..... .
RustyFarmall
07-14-2005 17:22:13
 Re: W6 Miss in reply to Yugrotcart, 07-14-2005 15:27:11
Your service manual has very detailed instructions on how to do that, using the notches on the front pulley and the pointer. Easy to do by yourself. I would set them at .020
