560 engine problems well sort of a 560 that is
old
07-06-2005 15:21:51
Well I have a galion road grader that has an engine that is like an engine used in the 560s. Well today I was running it for say an hour when it started to loose power and then just died. Yuo can get it to try to start but it just will not. I'm thinking thats a classic coil problem but would like other ideas as well. I know its getting gas but not sure about spark since its hard to trun the key and be at the engine at the same time and what is worst is I'm home alone for the next 2 weeks. Guess maybe I should see how many more tractors I can drag home before the wife gets back. LOL
El Toro
07-06-2005 16:49:20
 Re: 560 engine problems well sort of a 560 that is in reply to old, 07-06-2005 15:21:51
Hi Old, You can check for spark yourself by removing the distributor cap and remove the coil wire from the cap and hold it within 1/4" of ground. Turn on the ignition switch and with points closed, snap them open and close a few times and see if the coil wire is firing nice. Does it start after sitting for awhile or when it cools off? No fire present probably a weak coil.
Hal
Yugrotcart
07-06-2005 15:25:12
Heck, do like I do, when the wife goes away, I get the girlfriend over to help with the tractors..... ..... ..... ...
the tractor vet
07-06-2005 16:32:30
 Re: 560 engine problems well sort of a 560 that is in reply to Yugrotcart, 07-06-2005 15:25:12
He is probably like me , TO YOUNG FOR MEDICARE AND TO OLD FOR WEMMIN TO CARE.
old
07-06-2005 17:16:33
 Re: 560 engine problems well sort of a 560 that is in reply to the tractor vet, 07-06-2005 16:32:30
Well yes no and sort of. I have medicare but not because of my age. I'm a D.A.V. but what happened in the service didn't make me retired but I had to retire because of a crime and the guy that did it never saw a jail ceil. But any way I'm disabled and just play with the old tractors so I don't have to keep going to phyical tropy ya I spelled it wrong. I prefer to call it Pain and trocuer
Yugrotcart
07-06-2005 17:32:39
 Re: 560 engine problems well sort of a 560 that is in reply to old, 07-06-2005 17:16:33
Hmmmmm m, wife moved out, I bought a tractor to keep my mind straight. Wife moved home, still buying more tractors to keep my mind straight..... Maybe I should have stuck with one tractor, no wife,,,,, ,,,,,LOL
504
07-06-2005 19:28:40
 Re: 560 engine problems well sort of a 560 that is in reply to Yugrotcart, 07-06-2005 17:32:39
Old, I hope you are getting more rain down your way than we are up here (Hannibal) I have seen two codensers act just like bad coils. One was a 1968 Chevy and one was a 1972 Ford. Good luck kjm
