140- steering problems
Glen-Va
12-14-1999 07:50:46
Iv got a 140 with steering problems, you can turn the wheel one full turn before it starts to turn the wheels. Can anyone give me some advice on where to start, I know its probly a gear bad but where do i start first?
Thanks
Red Man
12-14-1999 15:04:51
 Re: 140- steering problems in reply to Glen-Va, 12-14-1999 07:50:46
Turn the steering wheel and watch where the lower shaft comes out of the steering gear box, I'd say your trouble is in the gear box.
Curt Cooke
12-14-1999 19:49:49
 Re: Re: 140- steering problems in reply to Red Man, 12-14-1999 15:04:51
Problems in the box. Verticle steer shaft is keyed to the steering gear, key is boken or keyway is wrecked. Verticle shaft moving up and down, worn upper bearing or missing snapring on top of it. Steer shaft moving in and out, bad bearing on end of shaft. Worn keyway on steering arm possible. Get the box and components disassembled and repair everything in your path.
Curt
