Kevinh about HM150
Jimmy King
05-17-2005 06:25:30
Hey Kevin have you used your plow yet, and if so how did it work.
KevinH
05-17-2005 10:35:52
 Re: Kevinh about HM150 in reply to Jimmy King, 05-17-2005 06:25:30
Yes, I used it about 3 weeks ago to do about 1/2 acre for a small corn plot. It took me a little while to figure it out, and still don't know how to adjust it properly(gauge wheel, tail wheel, etc). But it did a great job. The H pulled all 3 disks through some slightly moist ground in 2nd gear with no problem with the disks all the way down and the gauge wheel pulled up. Thanks for the info, and if you've got any more advice, I'll be needing it again in a few weeks to plow up the sorghum patch. Kevin
Jimmy King
05-17-2005 14:21:59
 Re: Kevinh about HM150 in reply to KevinH, 05-17-2005 10:35:52
Great!! About all I can tell you is try to keep your disc level and use your scrapers to level the way the dirt throws. They can be a pain to adjust, try not to let them get again the disc because that will eat them up. Second gear is good, an H will not pull it like an M. We used 1st,2nd, and 3rd with the H, when we got the M 3rd.
