hydraulic pump again
Hayfarmer
05-16-2005 20:30:09
Got pump off the SMTA and apart, can't read numbers oninner(distributor side) seal but believe I can match it through NAPA, shaft looks good. Hasn't beel leaking on engine side but wondering as long as I'm there if I shouldn't change it too. Looks like front and rear seal are the same, is tht correct?
Nat
05-17-2005 02:50:41
 Re: hydraulic pump again in reply to Hayfarmer, 05-16-2005 20:30:09
Since you have it apart, you may as well change the seals. If you're going to change the seals, label them and take them with you to NAPA so they can match them up.
