IY69 motor years
Giff in Ont.
05-16-2005 18:52:04
I got this motor, and I would like to know what year is it. (I know it would be like, between ten or so years, but thats a start). The # on the serial plate is IY69 97457. Bore: 2.500", compression: 110- 6.66:1. Max Piston clearence: .008. Plug gap: 0.35"R .025LP. Oil pressure idle: 7lbs. Maximum 20-30lbs. Firing order: 1342. It was origonally painted yellow. I don't know if that helps, but you guys (and gals) have been known to 'hit the nail on the head'.
Thanks in advance, Griff
Harold H
05-16-2005 19:04:19
 Re: IY69 motor years in reply to Giff in Ont., 05-16-2005 18:52:04
The IY 69 is a Continental engine. It was used in several IHC power applications, mostly replaced by the Cub 60 cubic inch engine as they became more available in the late 40's. It was built from at least the early 40's, I have it listed in one of my 1943 books, through the mid 50's, it is still in my 1955 book. Probably built longer. However, its use on IHC equipment was phased out in the late 40's. I don't have a list of Continental serial numbers.
Harold H
Griff in Ont.
05-17-2005 12:47:13
 Re: IY69 motor years in reply to Harold H, 05-16-2005 19:04:19
That seems to be the best info yet! thanks again for your time
Griff
