TRANSMISSION, SEALS
J. BYNUM
05-13-2005 17:20:19
I HAVE A 1946 M-FARMAII LEAKING OIL ON THE TRANSMISSION,NEED ADVICE ON HOW IS THE BEST WAY TO GO ABOUT REPAIRING THANKS
kfox
05-13-2005 19:09:11
 Re: TRANSMISSION, SEALS in reply to J. BYNUM, 05-13-2005 17:20:19
I just installed seals in my H a couple of weeks ago. Dropped the belly pump, and everything is right there. It's also a good time to repair the coupling on the driveshaft, if it needs it. I also replaced the throwout bearing while I was at it.
kfox
05-13-2005 19:28:59
 Re: TRANSMISSION, SEALS in reply to kfox, 05-13-2005 19:09:11
I forgot one important point. I think the M is about the same as the H and you might have trouble with the bellypump drive coupling on the transmission. I got a big prybar that would fit in the notches in the coupling , Put the tractor in 1st gear, locked the brakes and blocked the wheels. Then I set down with my back against the rear wheel and pushed on the prybar with both feet and smacked the prybar with a five pound hammer. Third lick, it came loose. good luck, ken
