Help identify a plow
Greg C
04-18-2005 15:47:26
This one may be tough, but I"m hoping ya"ll are up to it.I really don"t know much about IH hitch types, everyone around me runs green, and the one IH guy doesn"t know what type of hitch this is.My wife didn"t bring the camera home, so all I can do is describe it. It"s definitely IH, the hitch is a piece of 1 3/8" round bar stock, 29" wide. At each end is a bushing, about 1 3/4" dia. with a washer at each end of the bushing, each bushing and washer assembly is held in place by a cotter pin. The plow is connected to the round bar stock slightly off center. I"ve seen a couple of pictures in the archives that look similar, one was on Kelly c"s H, there was another that was painted (GASP!!) yellow and green. Other than that it"s pretty basic, two bottom, cutting wheel in front of each plow, and a depth wheel? in the back. Obviously I don"t use a plow much, as I don"t even know the proper terms, but I"m hoping you"ll be able to help me anyway. Thanks to all for your time and help. Greg
Greg C
04-19-2005 09:14:52
 Re: Help identify a plow in reply to Greg C, 04-18-2005 15:47:26
I found a couple of numbers this morning, on the main part of the frame IH 513532 RI, and on the second part of the frame IH515003 RI. The number on the plow is SA 4614 HO. Hope this helps, I should be able to post pictures tonight.
Thanks, Greg
Hugh MacKay
04-18-2005 17:51:36
Greg: From your description it is obviously a 3 point hitch plow. Are the plow beams at top and back rounded or curved and one piece all the way to the moldboard? Or is it straight beam on top, curved beam at bottom joined by flat plate on either side? It's probably going to take a photo for exact ID. How many bottoms? How far between beams on top, center to center? Are the plow wear parts 2, 3 or 4 piece? Any part numbers you see on forged steel parts will help. You dig up all that and someone will nail it, guarenteed.
KevinH
04-18-2005 17:46:56
third party image
Sounds like the HM150 I just came in from hooking up to my H. It attaches just as you describe and also has a bracket on each side that attaches to where the draw bar would attach to the axles. I looked for a picture, but didn't have one and it's already dark here. If someone else doesnt have something, email me and I'll take a picture tomorrow to see if it's what you have. Here is an illustration from the manual. Kevin
Greg C
04-18-2005 18:04:17
 Re: Help identify a plow in reply to KevinH, 04-18-2005 17:46:56
Kevin, that sure looks pretty close, I forgot to mention that there is a rod that comes from where the plow attatches to the hitch. It's about 7/16" dia. 3' long, with a slight curve at the far end, has a hole in the far end to attatch to something. I'll try to get some pictures tomorrow. Thanks for the help,
Greg
KevinH
04-18-2005 18:16:52
 Re: Help identify a plow in reply to Greg C, 04-18-2005 18:04:17
third party image
Try this for the rod you're seeing. Listed as #2 in this diagram.
