M govenor
Glen E.
04-10-2005 13:07:04
Is there an adjustment on an M govenor to make it a little more responsive? I know you can take the side cover off and adjust the rpms. It turns fast enough, I just want to get the stumble and hesitation out of it and make it lug a little better when pulling.
Hayfarmer
04-10-2005 19:36:02
 Re: M govenor in reply to Glen E., 04-10-2005 13:07:04
Would agree the "stumbling and hesitation" is usually carb related but it is also important that the shaft between carb and governor is free to turn and that adjustment there is correct. You could get hesitation there. If the engine RPM drows too rapidly on a pull it could be that the governor spring needs to be replaced.
Eric.S
04-10-2005 17:35:17
I agree with Rusty Farmall.Sounds like to me that you got carb problems.
RustyFarmall
04-10-2005 13:35:17
Stumbling and hesitation is not the fault of the governor. You have problems with either the carburetor, ignition system, or both.
