Block exchange
M 560
04-08-2005 06:13:19
will a M block fit in a H. I got a block out of a M. I'm putting a 560 block in the M and i'm trying to figure out what to due with the M block.
r4etired
04-08-2005 18:12:32
 Re: Block exchange in reply to M 560, 04-08-2005 06:13:19
How did you get the starter to work, the 560 fly wheel is different than the M ,Which fly wheel are you using
ChadS
04-08-2005 07:51:15
third party image
Here is me on my 6 cyl conversion tractor,,, it is a 263 in a H rear end, built to look kida like a 460. Nope, M engine wont fit in the H, the two top holes in the back of the block are taller on the block than the H. The 6 cyl, has 2 sets of holes in the back of the block to interchange between the small bellhousing 460, to the larger bellhousing 560. Chad
RustyFarmall
04-08-2005 06:18:47
The M block will not fit an H.
