39M rookie electrical question
Steve M
04-02-2005 16:11:15
I changed the M to 12 volt using a GM one wire alternator.Is there any issue with negative ground and direct connection from alternator to positive battery terminal ? Already have the 6 volt resistor between coil and switch.
Bob M
04-02-2005 17:46:25
 Re: 39M rookie electrical question in reply to Steve M, 04-02-2005 16:11:15
Your setup should work fine. Only issue is with a direct connection from the alternator to the battery you have no way to determine whether or not the alternator is working.
Suggest either installing a voltmeter or else wiring in the existing ammeter into the circuit to monitor on the charging system!
