FArmall 300
EWA
04-02-2005 15:49:39
I have a working FArmall 300 and need recommended oil grades for gears and PTO. I have been told from 90 weight to multigrade 30 weight. What is recommended oil for PTO?
skipper
04-02-2005 18:26:11
 Re: FArmall 300 in reply to EWA, 04-02-2005 15:49:39
EWA
I have the original owners manual that came with my 350 Farmall. For the live PTO it says use 2-qt SAE 10W. For trans/diff W/TA: 7-gallon SAE-75 gear lube, OR 1-qt IH TA Transmission lube additive to each 4 gallon of either SAE-10 or SAE-10W engine oil. When temps are consistently above +40F SAE-80 gear lube may be used. For trans/diff wo/TA: use SAE-75 or SAE-80 gear lube. same mixture as above may substitute or above +40F SAE-90 gear lube may be used.
Having written all that, most guys use straight IH HyTran in all the above componets, mostly because of the ability to hold moisture over a long period of time, I believe and the dealers do the same.
EWA
04-12-2005 21:27:56
 Re: FArmall 300 in reply to skipper, 04-02-2005 18:26:11
Thanks to all. As I stated I have been receiving different recommendations. The International-Case outlet had said a multigrade 10-30W. I have been using 90W, but light tan oil is leaking from PTO seal which has not occurred before.
CNKS
04-02-2005 18:35:27
When that was written, Hytran was either not available, or not in widespread use.
CNKS
04-02-2005 17:51:10
If it has a TA, use Hytran.
Andrew Z
04-02-2005 16:22:50
I run 80W - 90 in all my tractors. Andrew
