504 transmission
Greg Flugum
03-29-2005 06:29:44
I cannot find the fill level indicator on my Farmall 504 for the transmission/differential. The IT shop manual says it is on the right side somwhere, but I don't see it!
Can someone point it out or e-mail me a picture of what I need to see? I just fill it so the oil is over the visible gears thru the platform fill hole. thanks
Weldon
03-29-2005 07:18:57
 Re: 504 transmission in reply to Greg Flugum, 03-29-2005 06:29:44
You are correct my friend. The IT shop manual does say the fill level indicator plug is on the right side somewhere. It is on " the other right side". Look on the LEFT side of the rear transmission housing , down low, beneath the clutch pedal. About 2 inches toward the rear from where center section/clutch housing and rear transmission housing join , you will see a small hex head plug. A 7/16 or 1/2 inch wrench fits it. This is the " fill to " level. I always keep mine above this level because of using tractor on some rather steep hills.
