IH 1066 PTO won't dis-engage
Mitchell Dabbs
03-28-2005 13:25:29
Hello,
I have an IH 1066, and the PTO to the bush-hog won't stop turning when I put the contol arm in the stop position. You can see that the control arm is moving a piece of steel vertically that goes into the rear-end? but nothing happens to shut down the PTO. HELP!
K.B.-826
03-28-2005 19:25:40
 Re: IH 1066 PTO won't dis-engage in reply to Mitchell Dabbs, 03-28-2005 13:25:29
Does the lever seem to be moving through it's normal range of travel? Make sure nothing is interfering with the linkage. Most of the time when an IH PTO will not stop it is because the clutch disks are fried/warped. The only reason I bring up the linkage is that your're using a 3-point hitch implement. Once I was running a 3-point mount snowblower with the 966 and the top link pin slid over just enough to interfere with the linkage and kept the PTO from stopping, but I could definetly feel somthing was wrong.
Mitchell dabbs
03-30-2005 13:41:59
 Re: IH 1066 PTO won't dis-engage in reply to K.B.-826, 03-28-2005 19:25:40
Thank you KB826. Now at least I have a stating point!
the tractor vet
03-28-2005 13:32:33
Well it could be that the PTO brakes are wore out or broken springs or you are in need of new clutch discs and plates because they are warped or welded together .
mitchell dabbs
03-30-2005 13:46:17
 Re: IH 1066 PTO won't dis-engage in reply to the tractor vet, 03-28-2005 13:32:33
Thank You Tractor Vet! Mitch.
