656 injectors
TWL
03-21-2005 18:36:21
Would any of you know what to look for,and how to replace the injectors on a 656.Is it easy as it looks.Thank you for any help
Migraine
03-21-2005 20:19:30
 Re: 656 injectors in reply to TWL, 03-21-2005 18:36:21
The injectors on a 282 diesel can be stuck very tight but with a small pry bar and some penetrant they usually will finally break lose. Sometimes if you can get them to move horizontally a little bit first then they will come up out of there. Then put them on a pressure tester to check the spray pattern and if they have a dribble pattern they need new tips or total replacement. The ones last month for my 560 282 diesel cost 80 dollars each plus sending the old ones back . This was for rebuilt ones as new old stock are very hard to find. Make sure you change the washers down in the cups as well. Hope this helps. Migraine
