Order Farmall Cub Parts Online
Newbie needs help with Cub
Phillip Womble
03-08-2005 09:49:01
I bought a 1948 Cub last week. Engine sounds good, however there is an oil leak where the magneto mounts to the engine block. The magneto mounting bolts are tight so is it likely that there is a problem with a gasket?
MagMan
03-08-2005 13:47:50
 Re: Newbie needs help with Cub in reply to Phillip Womble, 03-08-2005 09:49:01
I can get you a gasket but I dont know about the seal. Do you ever so bussiness on ebay?Click on the name magman in this post if you want anything and email me. JON
scruffy
03-08-2005 12:57:07
Becareful not to tighten the mag bolts too tight in an effort to stop the leak, the tabs have a tendacy to break off.
Magman
03-08-2005 11:42:19
I cant say for sure where your leak is but Yes there is a gasket where your magneto mounts to the tractor. JON
George Willer
03-08-2005 11:59:29
 Re: Newbie needs help with Cub in reply to Magman, 03-08-2005 11:42:19
And ahead of that gasket is a seal... a fairly large one. The seal could be the source of the leak... it has to leak for the oil to get to the gasket.
Phillip Womble
03-08-2005 13:14:01
 Re: Newbie needs help with Cub in reply to George Willer, 03-08-2005 11:59:29
Where can I buy the seal and gasket?
